Hi
I just bought a new Windows XP based computer and it will not read any firewire devices. I downloaded SP2 in hopes of finding a driver that would fix this but I was out of luck. Any suggestions?
I'm running an AMD Athalon 64 3000+ with a gig of ram, and a K8V motherboard. My firewire ports are from both PCI and my case.
Thanks for any help you can give me
go to your motherboard manufacturer to download the drivers.
Try disabling one or the other. if possible, make sure that PCI slot 1 is empty, because often the built in devices have a conflict when that slot is taken (crappy design, I know).
Asus does not offer any drivers for IEEE 1394 for my motherboard. As for the second option I'll give it a try
If you go to the device manager, do you see a question mark somewhere? If so, a driver for the firewire controller hasn't been installed.
After installing SP2, go to the device manager and use "update driver" (or something like that).
I found that I had to do the same for my A64 mobo to get the USB2 driver installed.
Regards.Michael Tam
w: Morsels of Evidence -
what is the brand of firewire pci card? a friend used some crappy fmi brand that was a compusa's brand and it wouldn't work. i suggested he use a APAPTEC one and it worked great.
I actually did the pci slot swapping thing, its working perfectly now.
Thanks for all the help everyone -
Glad you found a solution.
you may want to check out this article:
http://www.tomshardware.com/howto/20040823/index.html
You can get drivers for your chipset from Via
http://downloads.viaarena.com/drivers/4in1/via_hyperion%204%20in%201_v453v.zip
it is likely your PCI firewire uses one of the two chips mentioned in the first article. there are links there.Be satisfied, the day is yours. If i have to explain, you would'nt understand.
dvd copied from HDD wont work on other players or computer??
By wundahoss in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2010, 17:34 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
will a USB2.0 Firewire Adapter work for me?
By J.Frost in forum Newbie / General discussionsReplies: 22Last Post: 21st Dec 2009, 17:20 -
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 13:01 -
Help: Computer wont turn on!
By NateDizzle in forum ComputerReplies: 12Last Post: 20th Nov 2007, 14:10
