Basically what this mean is not if - is better than + or vice versa..
What I'm asking is something like - Prodisc better or worse than its +? It seems that with some it's their - that is good while the + sucks, for some it seems to be the other way around.
Anyone have a good rule of thumb with brands or a good place to look at the different qualities among same branded discs?
It would really depend on what your standalone dvd player can play. Older standalone dvd players can not playback the + media. Only way it could is if you use a dvd burner that has bitsetting capability like NEC or LITEON burners. Use whatever media works well for you. DVD-R is more compatible with older standalone dvd players.
And some burners also have a tendency to burn one format better than the other.
Blah, blah, blah -
The complication with this question is that some media brands use different manufacturers for their - and + disks. For instance, Memorex for a while used CMC (crappy) for their - disks and (I think) Ricoh (good) for their + disks. This has changed, and will probably change again.
Others do the same thing, so you would have to, at the very least, put each - and + disks into a drive and run DVDinfoPro to find out who makes them. In addition, some older disks might be made by one manufacturer and new ones made by another.
It's a moving target. Whatever answers you get today could change tomorrow. -
Here is an interesting perspective on + vs - manufacturing processes and quality: http://club.cdfreaks.com/showpost.php?p=683372&postcount=86
Best TV brand for DLNA?
By trevytrev in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2014, 09:00 -
By trevytrev in forum Software PlayingReplies: 1Last Post: 29th Dec 2011, 23:58 -
Is VUESCAPE an ok brand?
By yoda313 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th May 2009, 19:13 -
Brand new member
By DavidCWM in forum Off topicReplies: 13Last Post: 9th Feb 2008, 01:02 -
Best brand of laptop?
By Tbag in forum ComputerReplies: 16Last Post: 7th Feb 2008, 22:59
