Hello,
I tryed to add a background sound in a DVD I made with Sizzle.
I dragged and droped an AC3 file into the appropriate box and had an error : "No audio track found in the file".
I tryed with several AC3 files, same error.
If anyone can help
thanks
Results 1 to 13 of 13
works for me, where are you getting this .ac3 from
What version of Sizzle is it?
Are you sure this is an ac3 track? Because if it is I dont see how you played it in iTunes.Originally Posted by RanXerox
I Just switched over to 0.5b2, and now ac3 tracks (created in a.pack) that used to work for background audio have stopped working. When I drop a file that ffmpegx identifies as ac3, 48000 Hz, 448 kb/s into the Drop Menu Background Audio box, I get the error message "Could not open audio source<cr> No audio tracks were found in <filename>"
Also, when I try to drop a 5:1 ac3 track created in ffmpegx into audio for one of my titles, I get the warning message "Potential audio problem<cr> Audio in <filename> is not 48KHz. It is not a valid DVD stream. The stream will be added, but DVD players may be unable to play it. It may also cause audio sync problems." ffmpegx identifies this file as ac3, 48000 Hz, 5:1, 448 kb/s.
Switching back to 0.5b1 seems to fix this problem (i.e., I am able to use the original ac3 files without warnings or errors).
adding a black background to subtitles
By coreymon77 in forum SubtitleReplies: 17Last Post: 11th Nov 2013, 01:26 -
No sound on movies, only background
By N3kr0 in forum Media Center PC / MediaCentersReplies: 1Last Post: 19th Jul 2011, 18:21 -
help! adding background music
By Keier in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2008, 15:30 -
Adding audio as background music whilst listening to the main sound
By Mrwoo1234 in forum AudioReplies: 3Last Post: 29th Dec 2007, 10:30 -
Hissing Sound in the Background
By Jenny in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2007, 02:04
