Hi I have been burning DVD-R using my optorite DD0203 with very few problems for 9 months. However since I updated my windows Xp to service pack 2 i have encountered problems.
I'm using nero 6 and have downloaded the update but when burning the screen says burn complete but when I click done it won't eject the dvd and i have to do it manually, and I then find despite my best efforts it won't play on anything.
If however I burn at 2 x speed(should be 4) there is no problems it burns successfully on dvd+rw at 2.4 speed as well. I have checked the dma is enabled and even after restoring to pre service pack 2 I get the same thing.
Please help
Hello,
Does your dvd burner have a firmware upgrade to deal with the new service pack?
I have downloaded the latest firmware but am unsure how to flash it as i don't want to ruin the burner.
Usually the firmware will be an executable file.
Double click on it and let it do it's work.
However do not do anything else on your computer while it is flashing.
Reboot after flashing has finished, and it will redetect the drive. -
I managed to update the firmware and everything is ace.
Thanks for all your help
A tool that does it all...correctly!!!
By bdirks in forum Video ConversionReplies: 15Last Post: 5th Jan 2011, 21:27 -
how to join correctly
By heruvim in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:55 -
Am I calculating resolution correctly?
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 24th Sep 2009, 08:37 -
Some sites not loading correctly?
By Ghtpua in forum ComputerReplies: 4Last Post: 26th Jul 2008, 18:03 -
Nero Vision not finishing
By jay2 in forum Authoring (DVD)Replies: 2Last Post: 17th Dec 2007, 06:00
