  1. I got a bunch of long mp3s mixes and would like to make cue files for them. Is there software that can do this? With a cue file, is this mean I can have my music nonstop but still can jump to different position on the mix, like forward, backward, correct???
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    If you use software like musicmatch they will let you add all of your mp3 files. Then you can shuffle through the whole collection or pick individual albums/artists (depending on how you stored your songs). Some software makes .m3u playlists. I guess I never heard of cue files.
    Kevin
  3. Try XDuplicator. I believe its free!!!
    Cue goes with bin . If you are thinking of playing like an audio cd, then it's a no no.They are image files for burning with program like Nero
  4. Originally Posted by vitamine
    See poster below... cue=bin, nothing more nothing less.
    What is your goal? What kind of hardware do you intend on playing these"mp3" files...
    Every mp3 I've ever created/played would ff, rew skip no problem...
    Details man, it's all in the details...
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
  5. Thanks I got those long mp3 mixes and it's a pain if you want to skip to certain parts. Is there a way I can get my mp3 still intact and can skip forward and backward to certain points. I heard a cue sheet will allow this, is this correct??
