Could someone please tell how i can remove a subtitle from an avi-file? or just replace it with another one![]()
If the subtitles were overlayed over the video within the AVI, then you cannot. They were "hard-coded" into the video frames and now form part of the video.
The more I learn, the more I come to realize how little it is I know. -
Hello,
If they are "hard coded" into the video you could try delogo for virtualdub. It won't get perfect results but it could work.
"Adopt, adapt and improve!"
There is a filter out (still in beta) that removes subtitles and logos from video. Tried that with a 20 second capture from TV and it did work. Although you would need a 20GHz (read twenty) to have descent performance.
You may want to try it out. Look at:
http://compression.ru/video/subtitles_removal/index_en.htmlThe more I learn, the more I come to realize how little it is I know.
How to Remove subtitle track from .MKV ?
By Clifurd in forum SubtitleReplies: 2Last Post: 14th May 2011, 00:32 -
Remove subtitle in black bar
By sltr1234 in forum SubtitleReplies: 4Last Post: 4th Dec 2010, 06:08 -
Best way to remove subtitle stream?
By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 06:15 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25 -
Remove subtitle stream from MKV
By NinjaPanda500 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 15:59
