  1. Im in the midst of backing up a few dvds for a computer-less friend and ive hit a problem. Im using DVDBackup, DVD2onex and Toast to burn. Everything is fine til I burn it, then the sound is not lined up correctly (about 2 seconds ahead). I tested the VIDEO_TS folder right before I burned it and it was fine. I did a few others the exact same way and they were fine, so this is really frustrating. Thank you for help.
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Post burn are you playing on your computer or on your non-computer using friend's DVD player?
