when transferring files lets say between my two internal hds, both 7200 rpm, i have recntly noticed a big slow down, also in my unzipping from lets say winrar or winzip, i downlaoded a vid the other day that was more than a gig, and it took me a half hour to complete the process and put the files where i wanted them.
What im asking is, doses anyone know of or ever heard of any slowdown problem like this, maybe its something i should change in my bios?....is there something in the registry i can correct or upgrade....id like my stuff to really speed up, i remeber when i use to do it in under 5 minutes, all of it, now its taking forever.
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
SIRCOOKS, it could be almost anything. Here's what I believe is the most likely ASSUMING you have not changed anything hardware-wise. Let me know if you have changed any hardware lately.
1. Spyware / Adware running
2. A virus / trojan / worm
3. Too many prgrams loaded, not enough memory
4. Windows Indexing, Restore function, crowded hard drive, fragmented hard drive.
5. Recent XP upgrades like SP2 -
i haven't defragmented in a while, but that was only like a month ago, i know they say to do it everyt month, but i dont think thats to much of a problem, ill do alot of virus checking andother stuff tonight, holla back with any other suggestions
Usually defrag is not the problem unless you have pretty full hard drives and you are copying large files (especially on a FAT32 file system). Still, it couldn't hurt to check. You could aslo do a ctrl-alt-del and check the running processes sorted by cpu utilization. You could have a renegade process (program, trojan, worm, etc.) stealing cpu cycles. At rest, your system idle process should be running 97 - 99%.
ill check that to make sure as well when i get home.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
