Hey all,
After several months of stupidly using Pinnacle Studio8 to render my DVDs, I finally got wise and switched to TMPGEnc DVDAuthor. The only thing I miss is Pinnacle's far better menus... They have one "stock" menu in particular that I used and modified for every DVD I made.
Is it possible to "import" this stock Pinnacle menu into DVDAuthor? I've attempted to duplicate it using the existing options in DVDAuthor but the results still look pretty crappy. (That said, I ain't switching back, crappy menus or not...)
--Rich
NOPE! The only thing you can do if to improt a background image to replace the 4-5 ones that comes with TDA. You are stuck with the buttons though. Hopefully they will add some sort of meny editor with a future release. Such an excellent program and yet such a lousy meny editing section. If you can live with it, it is excellent and pretty much works perfect everytime. I have not used their burner as of yet though. I usually just create the DVD to a folder and burn with another program.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
The backgrounds for Pinnacle end with extention .xpg. Can you convert .xpg to .jpg??
When it sounds too good to be true, it usually is!!
dvdauthor, GfD - Animated menus hesitate at end of loop
By jsbullock in forum Authoring (DVD)Replies: 2Last Post: 29th Jun 2009, 02:55 -
Creating DVD menus with DVDAuthor(linux)
By sumit_pankaj in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2009, 12:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
GUI for dvdauthor - continuous music over menus?
By GeorgeLucas in forum Authoring (DVD)Replies: 2Last Post: 27th May 2008, 19:20 -
Looping audio on GUI for DVDauthor menus weird problem
By chewie8008 in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 10:16
