shameless post-whoring, BJ_MOriginally Posted by BJ_M
Is Baldrick catching up ?![]()
Closed Thread
Results 91 to 120 of 153
If in doubt, Google it.
nah -- i just knew that Jorge was going to ask again and i thought i would get a jump on him
i am not even in the top 10 or maybe not even in the top 20 for week/month /etc ..
the true post whores have taken over (i dont even post much in off topic)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
so would I be right to assume that this thread has gone nowhere in the past day or 2 in terms of success ?
it is decidedly going backward ....
i cant even anymore figure out what is wanted as it changes hourly .. i know this must be a set up . on candid camera or something"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Try Eazy VCD and this guide, if you haven't already
I would suggest that you tick the "Delete Temporary Files" box and choose "Make MPEG Files". All you will have when finished is the MPEG file(s), and you just burn each one to a CD using Nero or your favorite authoring/burning software.
Has it finished ?
Has it actually put up a notification on the screen telling you that it has completed ?
riped_1.vob is only the first stage of the process, unless you have "only rip VOBS" selected.If in doubt, Google it.
Look to the left under Tools and search for Nero Burning ROM.
You can also go to their website www.ahead.de and download a demo version.
cdrwin is also very good for burning bin/cue (they invented it) ..
burnatonce i never heard of but sounds good.. here is the link
http://www.softpedia.com/public/cat/3/1/3-1-13.shtml"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
see here for detailed instruction
https://www.videohelp.com/forum/viewtopic.php?p=1051890#1051890"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
