Yeah, I know about that, but I just wanted to convert some of my paintball videos into vcd's so I can watch on my dvd.
Closed Thread
Results 61 to 90 of 153
Originally Posted by Jorge
From the Tools menu, choose Burn CD and choose Video CD from the submenu to render your project and burn it to a Video CD (VCD).
Video CDs can be played in many home DVD players and on computers with a CD-ROM drive and VCD player software.
From the Tools menu, choose Burn CD and choose Video CD from the submenu. The Burn Video CD dialog is displayed.
Choose the movie file you want to use:
If you want to render the current project, select the Render format radio button.
a. Edit the contents of the File path box to specify the name and location of your rendered file.
b. Choose a template from the Template drop-down list to specify the parameters that should be used for rendering your file, or click the Custom button to create a new template.
c. Select the Render loop region only check box if you want to use only a portion of your project. If the check box is cleared, the entire project will be rendered and saved to the Video CD.
d. Select the Stretch video to fill output frame check box if you want to reformat your video so it fills the output frame size listed in the Description box. When the check box is cleared, the current aspect ratio is maintained, and black borders are added to fill the extra frame area (letterbox). This option is useful when the desired output format does not match the frame aspect ratio of you project.
Clear the Fast video resizing check box if you see unacceptable artifacts in the rendered video. Turning off this option can correct the artifacts, but your rendering times will increase significantly.
If you want to use an already-rendered MPEG file, select the Use an existing file radio button, and enter the path to the file in the File path box (or click the Browse button to locate the file).
Select recording options for your CD-recordable drive:
a. Choose a burn mode.
Item
Description
Burn CDs
Begins recording audio to your CD immediately.
Test first, then burn CDs
Performs a test to determine whether your files can be written to the CD recorder without encountering buffer underruns. No audio is recorded to the CD during the test, and recording begins after the test if it is successful.
Test only (do not burn CDs)
Performs a test to determine whether your files can be written to the CD recorder without encountering buffer underruns. No audio is recorded to the CD.
b. From the Burn speed drop-down list, choose the speed at which you want to record. Max will record using the fastest speed possible with your drive; decrease the speed if you have difficulty recording.
Your movie is recorded to the CD. When recording is finished, you can select the Save movie file check box to keep the MPEG file that was rendered, or you can clear the check box to delete the file.
Click Finish."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Originally Posted by mats.hogberg
C'mon Mats, sharing's caring !If in doubt, Google it.
Alright, now that I figured how to do the whole vegas thing. I now want to convert dvd movies into vcd or svcd. I downloaded the program Easy vcd. And I followd the guide on how to do it. The thing is that I noticed its saving the files in VOB format; after its completely done ripping the dvd, what do I do with those files so I can burn them into my CD)-R and play the movie.
just get dvd2svcd and hit the go button
If I used DVD2SVCD, and converted the movie, would I just burn it, after the conversion.
Originally Posted by JorgeIf in doubt, Google it.
Ok, I want to use easy vcd, as I have downloaded it already. Here is the little problem, the movie I was converting in easy vcd is already done, the final step was for it to convert in tmpgenc, and my computer froze while I was using the internet, and it restarted. How can I go back to the convertion process where it was originally started.
I think I can, I think I can......Anyways how can I do it. I had dvd2svcd but It said I needed Cinema Craft Encoder, doesnt that cost like 1000 bucks. Is their an alternative.
it costs 1995$
dvd2svcd comes with a free encoder (i think -- anyway it supports one)
-- like i said --
just hit go and let it do everything , you dont have to do anything ..
you will end up with a bin/cue file which you can burn with lots of apps ..
it will take awhile though as i see you have a P3 with winME -- maybe a whole day in your case to encode .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I'll see what I can do. When I Intalled it, and opened the movie I wanted to encode, it gave me a message saying that I needed cinema craft encoder, and on top of that I could not find the go button anywhere. It had so many options that it drove me kind of crazy.
Ok lets say I did do the encoding using dvd2svcd and it finished the whole process; what do I do next with the file or files it creates, do I need another program, I think its isobuster right. Is there any tutorials on how to use dvd2svcd???
dvd2svcd is as simple as it gets -- and all in one ..
the only thing is can not do is hold your hand and burn the disks -- but maybe those are coming also .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Ok, its not working at all, I opened the dvd and it did not work. Is there any other program that is good. Ive downloaded dvd2svcd many times and it didnt work so forget that one. Please help me out. Can it be done it vegas 4.0.
if you can not get dvd2svcd working -- i suggest giving up
really --
nothing is simpler"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
