Do I need some special program to download vcdimager, kind of stuck here, if anyone has a link to where I can download it, then that would be great.
Closed Thread
Results 31 to 60 of 153
just render to mpeg1 and register vegas mpeg plug in with sony on-line or by phone ==
it is included with vegas -- you just have to activate it (no additional cost)
it is covered in your manual ..
i can have sony people contact you if you need help - as i know many of them very well .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Jorge:
here is a link to vcd imager, I don't know if it includes vcd imager gui too but I think not.
ftp://ftp.cise.ufl.edu/pub/mirrors/GNU/vcdimager/
if you are referring as how to use vcdimager, just download the vcdimager gui (click on the vcdimager gui 0.6 link at the top:I downloaded it, what next????
https://www.videohelp.com/vcdimagergui.htm
and extract it to the same folder. Then how to use vcdimager gui:
Any other questions, just ask me.Import your mpeg files into vcdimager and set the bin output file. All this will do is change your mpegs into dat files (not true mpegs) and add a few other files so that your dvd player will recognize them. This is stored in a .bin file. Now download isobuster. The open the .bin file in isobuster.
Extract all those folders to a directory. Then open up whatever burning software you have and select "make a data cd". Then drag all those folders (and only those folders) onto the cd and burn. That's it. What you pay for in commercial software is to automate that process so people don't have to spend the time and energy, plus you can make menus. I am happy to help with any other problems.
Ok I have vcdimager GUI, so now I download the vcdimager 0.6 link, and extract it to vcdimager GUI folder right.
..'scuse me for butting in again, but have you read any of the numerous guides on the subject of AVI to (S)VCD found left? If not, I can assure you, it's time well spent, instead of asking a new question for each step (and each software) required to accomplish the task, and waiting for someone to supply an answer.
/Mats
Ok I downloaded VCDimager and VCDimager GUI, now I went to open VCDimager, but its a .tar type of file, how do I get it to work. I can open VCDimager GUI just fine, but VCDimager I cant. Need some help.
.tar is a filetype that winzip can't handle. Download WinRar, this will open it. The link is here:Ok I downloaded VCDimager and VCDimager GUI, now I went to open VCDimager, but its a .tar type of file, how do I get it to work. I can open VCDimager GUI just fine, but VCDimager I cant. Need some help.
http://www.download.com/WinRAR/3000-2250-10259256.html?tag=lst-0-1
Just make sure to extract vcdimager and vcdimager gui to the same folder.
Wow, Ive never had so much trouble in my life. Ok so first things first this Is what Ive done so far.
1. Ive downloaded vcdimager
2. Ive downloaded vcdimager GUI
3. I downloaded WINRAR (dont know how to use it that well).
4. Im lost from there.
Jorge, after you get the files conveted to VCD or SVCD, go here
http://briefcase.yahoo.com/rogergray1964. There will be a folder named Jorge. Click on it and you can download VCDImagerGUI as a regular zip file from there. It already contains VCDImager so you won't need a separate version of it. That program will create a cue & bin file that you can burn with nero or other burner.
Hope this helps.
Have fun stormin' the castle!
RogThere are many ways to measure success. You just have to find your own yardstick.
Yeah there is an svcd template. I really dont have any other encoders. I was trying to get this done using avi 2 vcd. But a member here said that all of it can be done using vegas 4.0.
Well AVI 2 VCD will also work. It's real simple but kinda slow. You could also try avi 2 mpg2 or Tmpgenc which has free mpeg2 for 30 days and free mpeg 1 encoding. AVIDemux will also work but will require muxing the file back. But any of the encoders should work fine. Once you get a file encoded, you can use VCDImagerGUI or VCDEasy to author it to a cue/bin file then burn it with Nero or Burnatonce. My advice is to try burning just 1 file to a VCD (Maybe on a CD-RW to save on CD's) then when you get used to it go ahead and burn all the files. Burning VCD/SVCD/DVD is not rocket science, but it can be tricky, however, once you get used to it, you can burn stuff in your sleep.
Hope this helps.
The archos can read a large variety of avis, xvids, divx's different versions also.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
