I am getting married soon and I want to gather up pictures of me and my fiancee and put them together in a short video with music playing in the background. Like a slideshow on the screen where it would just flash picture after picture with music in the background. Is there a simple way to do this? I dont have any video editing background - so is their an application that i can put my digital pictures on and have it scroll through with music in the background? Thanks for the help and my fiancee thanks you too!
Results 1 to 12 of 12
Memoriesontv can do that. You can get it from the Tools menu.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
There's a bunch of apps that will do that. https://www.videohelp.com/tools?s=28#28
Most editors/authoring programs can be used as well. -
Most of those you have to pay for - I have a couple of applications already like RecordnowDX, powerDVD, etc. I got the Pioneer A04 and it came with some other apps as well - I am at work and cant remember what i have at home. Are there any free ones i should try?
I have used a Freeware called Slide Show Movie Maker. You can add music. pan and zoom and have transitions between photos.
wwjd -
Slide Show Movie Maker is pretty good.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
When i try to use this software and start the creation of the slide show it locks up my computer. Am i adding too many pictures? Does anybody have any experience with this that can help?
ProShow Gold or Ulead Video Studio. For stills, they can do about the same thing, but ProShow is easier (as still shows is what it does - UVS can do a lot more...)
/Mats -
Pro Show Gold ROCKS!
This is by far the easiest program that I have ever used for what you are needing to do. I currently use this for many of my families that want a simple yet professional looking show. Weddings, Holiday Memories etc... You have so much flexibility and now with the new upgrade that they have introduced, awesome is all I can say.
Wish you well.
http://www.photodex.com/products/proshowgold/
Mark -
I was then told to use Moviemaker 2.0 that came with Windows XP - But this program is locking up on me too - i import the pictures, add the audio and then start to make the move file and it locks up about 75% of the way. How do i trouble shoot this?
Seems like many video related applications lock up your computer - Have you by any chance installed any codec packs? If not (and maybe even "if"!), a clean XP installation might be the only cure...
/Mats -
No - I have not loaded any codec packs - I guess i will try a new installation. thanks for the advice!
Video no longer has picture, only sound in all programs
By mejohnso in forum Newbie / General discussionsReplies: 7Last Post: 26th Mar 2010, 10:26 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
Video has sound but no picture from encoded avi file. What's wrong?
By Ivor Bigone in forum Video ConversionReplies: 4Last Post: 30th Jun 2008, 10:01 -
Question regarding making an existing video larger
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2007, 09:15
