Hello,
I need a software that can create visual effects on video. I don't need the usual effects like scene transition filters or crop image etc. I need to be able to completely transform the image or part of the image, something like photoshop filters for pictures.
Althow I preffer something not very expencive, any suggestion would be appreciated.
Thanks,
Results 1 to 10 of 10
Have a look at Wax http://www.debugmode.com/wax/ - it's free! You can use it as a standalone, or plugin with Vegas, Premiere, and Editstudio editors.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
well, Premiere can use Photoshop filters on video footage...
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
After Effects would be the perfect job for that task, though it does have a heavier price tag and learning curve, but when mastered theres not much you cant do.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
shake with Sapphire , digital fusion 4 , fire/smoke/flint/flame , combustion , Boris red, AE , Houdini ........ several others ..
how much you want to spend -- the above list starts at 1000$ (AE) and goes to 200k
:P"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You can always go with moviemaker if you have xp. If you don't like the ones that come with it I think you can download others.
How about Cool 3-D Production, here's a sample. It's a still image placed on a square which has then been warped, this warping is animated. You can add your video as a background and do the affects over the top. Little over $100
Thank you all for your suggestions. I think I 'll first try wax (which is free!) and then I 'll download the trial version of After Effects to test it.
Wax is beautiful-(thank you Madame Tussaud)!!
Nice software-a bit steep learning curve but manageable by members here.
Thanx Safesurfer for bringing it to our notice.
New Vegas Effects Software
By budwzr in forum EditingReplies: 0Last Post: 21st Sep 2011, 12:03 -
what is the best software for mixing video and images with special effects
By ukcalibrauk8 in forum EditingReplies: 0Last Post: 24th Aug 2011, 03:00 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 10th Aug 2010, 00:16 -
Special effects software?
By ProducerHarley in forum EditingReplies: 5Last Post: 30th Jul 2008, 11:12 -
Title Effects, Video Software
By insanefirewall in forum EditingReplies: 3Last Post: 21st May 2007, 12:39
