I'm currently improving the audio in wav files that yhave been extracted from music videos. The audio from the DVD vob file AC3 and I extract this to a wave file first.
I use Wavelab 3 to edit the volume and tone, and this is done at the sample rate of 48khz.
I then use Soundforge to convert this back to a mpa audio file so I can mux this back with the original video using TMPG.( I do not want to reconvert the video stream)
The problem is the audio is out of sync by a few hundred milliseconds to 1 second or so.(this is usually from the start of the file) Is there a delay correction I need to account for, or a better way of doing this so I don't loose audio sync.![]()
Results 1 to 1 of 1
Ripping Music Videos From DVD
By skywalka in forum DVD RippingReplies: 15Last Post: 17th Apr 2012, 12:27 -
2 videos with different frame rate sync problem
By dgiulian in forum Video ConversionReplies: 1Last Post: 26th Mar 2011, 21:40 -
make music videos DVD
By litueche in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2007, 08:35 -
Recording gameplay videos, audio out of sync
By xmmm in forum Newbie / General discussionsReplies: 0Last Post: 14th Nov 2007, 18:11 -
Distorted Cracky Audio with burned music videos
By DatBoyYank in forum Newbie / General discussionsReplies: 6Last Post: 10th Aug 2007, 02:25
