What is the deal?
And how do I make it load faster?
Results 1 to 9 of 9
I think you have to elaborate a little o that one...
/Mats -
The file I play in my HD.
When I execute the file takes a long time to load and play. Or skip ahead while the video is playing, it lags for like 10 seconds, then finally plays. -
I would blindly say that your PC is possibly not operating as effectively as it could be. There could be any number of reasons for this from a fragmented hard drive to a cluttered registry or corrupt codecs. It might be an idea to fill in your computer details so that we know exactly what type of machine and OS you are using.
If in doubt, Google it. -
Could also be a poorly indexed file. WMVs can be encoded without any index at all (for streaming purposes i think)
My computer is newly reformated.
Win 2000 Pro SP4
AMD Athlon XP 2000+ @ 1.67 GHz
ECS K7S7AG
256 DDR RAM
It also had the same problem when I was using XP. -
Is it 1 file or a couple of files or all WMVs ?
Could Windows Media Player be set up to check the web for codecs ?If in doubt, Google it. -
If loading a WMV file on Media player takes a long time and then skipping forward or backwards appears to lock-up media player for a few seconds up to a few minutes, it means that the WMV file is not indexed.
With non-indexed files, media player (or any s/w that reads the file) needs to scan every frame until the approximate location of the skip.
ASF Tools can re-index the file so that it seeks fast.
In case you wonder why the file is not indexed in the first place, it's because removing any indexing information on streaming files saves this extra bit of bandwidth required to stream them efficiently over dial up lines.The more I learn, the more I come to realize how little it is I know.
MPC failing to load subtitles on long movies?
By crossmr in forum SubtitleReplies: 3Last Post: 26th Feb 2011, 09:27 -
avi2dvd wmv load problem
By simonrule in forum Video ConversionReplies: 4Last Post: 23rd Sep 2009, 13:44 -
Workflow Help with MTS/M2TS --> WMV and AVI.MKV --- (long, Canon HG10 sr
By RonUSMC in forum Video ConversionReplies: 8Last Post: 24th Jul 2009, 03:49 -
Conversion of .mov to .wmv takes too long w/ analog videos...
By Nintendo Fan in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 15:47 -
flv server load compared to wmv
By Fking in forum Video Streaming DownloadingReplies: 1Last Post: 18th May 2008, 07:28
