After i upgraded to 10.3.5 i cant seem to make my dv cam work with my mac , i want to import film to imovie or final cut and it tells me no cam was hooked up .. is there anything i have to do to make this work again ..
Thanks in advance
Peace
Joe
The most common fix to communication port issues after updating the System is to download the combined system updater and apply it again. Sometimes it takes installing it twice to get all working right.
Naturally there are the other maintenance steps of repairing permissions and running Disk First Aid or Disk Warrior. But I think reapplying the 10.3.5 combined updater will fix your issue. -
the other ting I have encountered is that after the
last few updates, both FCP and iMovie 's
preferences get corrupted. This happened to me
with iMovie 4 and 10.3.5.
To fix it I went into /Library/Prefrences
and found apple.com.iMovie.plist
and threw it away ( with iMovie closed of course).
upon re-launching iMovie, I was able to import
through FW again."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Actually guys
I have seen this before. #1 thing to do once installing any software piece... Go to Disk Utility and Repair Permissions! I can't tell you how many problems you will avoid if you do this (as far as video stuff is concerned) Hope this helps.
Oh, and TerryJ was right about the prefs, that's #2! Good luck! Peace"What's a matter Colonel Sanders???? CHICKEN???!!!!
Problems importing Quicktime movies into Sony Vegas
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:31 -
problems importing widescreen video
By video_enthusiast07 in forum EditingReplies: 1Last Post: 10th May 2010, 03:18 -
After Effects to Premiere... importing problems?
By Saibot in forum EditingReplies: 1Last Post: 21st Feb 2009, 23:48 -
Problems with importing converted vob into Premiere Pro
By fishytastic in forum EditingReplies: 6Last Post: 16th Oct 2008, 15:18 -
mpeg sync problems after importing dvd
By blubot in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2008, 12:31
