Results 1 to 13 of 13
    Sep 2003
    does anyone know what the difference between dvd-rw and dvd+rw is? is one used to movies and the other for games or something?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    two different formats of essentially the same thing - just like heavy or light beer.
    If in doubt, Google it.
  3. DVD+RW is better than DVD-RW in at least the following way:
    After recorded in DVD (+/-) Recorder, DVD+RW can be played immediately in any DVD players. In case of DVD-RW you have to click the 'Finalise' button (it takes 60+ minutes) before it can be played.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think you are doing something wrong.
  5. Member Cornucopia's Avatar
    Must be.
    I can do a full DVD-R to DVD-R dub in ~5-7 minutes!
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think we're talking RW here.
    Sep 2003
    so there is nothing that a dvd+rw can do that a dvd-rw can't do?
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    correct.
  9. Originally Posted by jimmalenko
    You must be drinking too much....
    FYI, when comes to RW's, most of the slightly older DVD ROMs or readers could only read -RW.
    It's time to kick some butts, and presto ( if you know what I mean )
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    is that right ?
  11. Originally Posted by jimmalenko
    is that right ?
    Go do some home work and figure it out yourself, or contact DVD ROM manufacturers.
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    is that right ?
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    There are different procedures to making the two formats compatible outside of what they were burned/recorded on....but that is taken care of by either computer software or the DVD recorder.
    Some recorders make discs that are more compatible than others BUT that is the fault/feature of the DVD recorder....NOT the format.
