Hi, I am not sure where this topic should be so I will put it here...
I have recorded my wedding for my family in Europe & Asia and I was wondering if the format I made it in will work on their TV's and DVD players in their countires, here is the info of the DVD I made:
Region: (1,2,3,4,5,6,7,8)
Video: MPEG-2 720x480
(NTSC)
4:3
Audio: 2ch 48Kbps 16 bps (Linear PCM)
Will this work, or do I have to re-do the movies and if yes to what format should they be, or can I use the IfoEdit trick??
Please help and I really do appreciate all the support you all give, thanks!!!
Do not worry because back to several years ago, most of the DVD players and TVs in East/South East Asia already support multi system, which means that NTSC or PAL can be playback well.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
Dell Bans the Export of Electronic Waste to Developing Countries
By noemi7 in forum ComputerReplies: 0Last Post: 15th May 2009, 04:08 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
HDTV compatibility between countries
By pacopaco in forum Off topicReplies: 0Last Post: 26th Apr 2008, 23:30 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
