Results 1 to 22 of 22
    Sep 2003
    Big Apple
    Hi all,
    I reinstalled windows on my pc before installing Doom3, so it could run smoother. After the reinstall it would constantly restart by itself and then a windows mess would popup. A microsoft generated report would tell me that a serious error is caused by a driver or hardware. I reinstalled windows and now it doesn't restart as often as before but still does. Just a couple of mins ago I got a blue screen of death (I am running XP Prof.) and after manually restarting windows would not load. I had to press the restart button like 10 times for windows to finally load. What can it be?
    I thought that it might be that my pc overheats?
    my temp right now is
    CPU temp 51c/123F
    System Temp 40c/104f
  2. Member Reaper88's Avatar
    May 2003
    seems kinna hot, do you have an automatic shutdown temp set in your bio's?
    Sep 2003
    Big Apple
    I don't think so. I never turned it on. Where in bios is that setting?
    Also it doesn't shutdown it restarts and then gives me errors.
  4. Member Reaper88's Avatar
    May 2003
    Just check out your bio's setting, not sure all are alittle different. Just look around till you find it. I do believe that temp shutdown setting are already pre set in your bio's. I am not sure if this is your problem its just a thought.
    Sep 2003
    Big Apple
    I think I found it.
    It was not on.
    What else do you think I can do to find out what it is?
    Also what can it be?
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    You may want to double check that all your fans are running. Sometimes a fan or two makes all the difference. If they are, you may even want to add some fans, although if it was running before, something else may need to be done, but more fans is a temporary fix. Also, try blowing everything out with compressed air to make sure none of the intakes or fans are clogged.
    Nothing can stop me now, 'cause I don't care anymore.
  7. Member Reaper88's Avatar
    May 2003
    Are you sure you have all the correct drivers for you hardware installed?
    Sep 2003
    Big Apple
    Yeah, I am pretty sure. After first install it would restart all the time. I reinstalled windows and now it only restarts some time and actually haven't in sometime, untill today again when for the first time I got the screen of death. I reinstalled windows a million times before and always dled drivers from the same places. (man. websites) I am running 1.8 amd, 521 ram, ti4600, 120gb wd adn 80wd and I only have one fan on the processor. My case is open though. I am going to add some fans now. Are there any you would recomend with thinking ahead because I am planning to upgrade very soon. I rather spend a little more on fans but have it do a good job. thanks a lot for your help guys. I hope it's the overheating even though I doubt it.
  9. Member Reaper88's Avatar
    May 2003
    amd's do run hot but shouldn't be that hot. I had a problem awhile back with my amd running hot and my pc would freeze up and temp alarm would sound, sometimes it even rebooted. Ended up my power supply was bad and not getting enough power to my fans. So problems like your could be anything. Trail and error is the best way to figure these things out.
  10. Originally Posted by slimmx
    CPU temp 51c/123F
    System seems a little high but CPU seems ok. Shouldn't reboot at these temps.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  11. My CPU is currently running at 62 deg C, motherboard 28 deg C. No bother, perfectly stable.
    I got that "serious error due to drivers or hardware" when I clocked my CPU too high. Are you overclocking?
    Failing that, you could swap the RAM out and try a new stick.
    Jan 2003
    Nassau, Bahamas
    open your comp and see if your heat sink is running correctly on top of your processor, check to if all fans are spinning, is your comp in a cool place, if not, try this
    http://www.newegg.com/app/viewproductdesc.asp?description=35-888-003&DEPA=0
    these work great...
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Sep 2003
    Big Apple
    No, I am not overclocking. I am thinking that it is my video card driver. I dled the newest video driver from nvidia.com. Did anyone else have problems with it?
    My pc started to restart again all the time. Like 5 times in a couple of hours, and always with blue screens.
    Sep 2003
    Big Apple
    Could it be that my video card is overheating?
    Jan 2003
    Nassau, Bahamas
    has the fan on it stopped spinning, or yet again, open your case and make sure that everything is spinning...
    Washington, D.C.
    For a different tack, look on the M$ site regarding the SP2 automatic restarts. That is if you SP2 installed.
    Sep 2003
    Big Apple
    No, I haven't installed sp2. This is funny but my pc hasn't restarted in a couple of days now. I don't know what the hell is wrong with it. I am going to upgrade very soon. I will need some help in choosing a motherboard and some other things. I appriciate the help.
    Slimmx
  18. Member
    Mar 2002
    Hawaii
    It's probably a windows or video driver related problem. AMD chips run hot. Mine idle at 52°C and run at 60+, under full load. They start to get unstable at about 90°C, according to AMD's website.
    I would try a fresh os install again, and wipe/format the os hard drive. Then, try the video card drivers. Then, swap your RAM, if you happen to have any other compatible sticks lying around.
    Have you always been using XP?
    Jul 2004
    Canada
    Does anyone know of any freeware out there that can show the temperatures in Windows without having to jump into the BIOS to see.
    I figure that if overheating is a problem, then you might want to monitor it somehow in real time while you are sitting in front of yer box . . .
    JeeDub
    Just because you are paranoid, doesn't mean they aren't after you . . .
    JeeDub
  20. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Look into Motherboard Monitor 5.3.7.0 found here:
    http://www.softpedia.com/public/cat/13/5/13-5-1.shtml
    Make sure it fits your chipset but it seems to hit all the major ones. I have not tried this one but there are several free ones out there.
  21. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I use this one at home. It doesn't support many MBs, but I happened to get lucky.
    Here's a screen grab of how I have it configured:
    https://www.videohelp.com/forum/viewtopic.php?p=980442#980442
  22. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    if you have asus, just use their Asus Utility Probe to give you all of that information.
