my norton 2004 and avg antivirus icons in my systray disappeared didn't do anything...is this a virus at work or something...
read somewhere that there are virus that can "kill" antivirus program...
Results 1 to 10 of 10
hacking the Net using typewriter :D
What OS are you running? Sometimes XP hides inactive tray icons.
Nothing can stop me now, 'cause I don't care anymore. -
nope it does not comeback when i rebooted...
im using windows xp PRO SP1...im familiar with XP hiding inactive tray icons and when i click on the << of the tray icon to unhide hidden icons, my antivirus virus icons (norton and avg) is not therehacking the Net using typewriter :D -
Open Task Manager and look for NAVAPW32.EXE under Processes. If you see it, Norton is still running.
Congratulations, you've just bested Norton bloat-ware
Could just be a glitch. I had a crash during an auto-update that caused exactly that. Reinstalled it and downloaded the updates again and it worked fine. Just make sure to try uninstalling it first. You may also try to repair it if given the choice. -
As an example, Kerio Personal Firewall does not automatically start up if you closed it. Run the program again like somebody else said.
i only have navapsvc in my task manager
i tried to run Nortor 2004 click on Enable Auto Protect so the auto protect icon in my systray will comeback...but it cannot be Enabled. i keep on clicking but my autoprotect stay in OFF status.
i didn't use auto update. i manually download my virus defenition using download accelerator and run the updater. faster for me.
this happened to me in the past. reinstalling norton seems to fix the problem. now it happened again. im tired of reinstalling the damn antivirus....i was hoping others could suggest other solution.
this usually happen when dllhost.exe appear in my task manager. is this file a virus? i tried to end the task but it keeps on coming back.hacking the Net using typewriter :D -
my norton 2004 icon disappeared the same time my Avenger AVG antivirus icon disappeared. and i got to reinstall the two program to fix the problem...quite strange...
Pinnacle 12: Project disappeared
By avz10 in forum Authoring (DVD)Replies: 1Last Post: 11th Apr 2011, 18:41 -
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 05:47 -
titles disappeared after conversion
By izzykatz in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 17:25 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 09:51 -
Lite-On 1673S disappeared...
By blasedeviant in forum DVD & Blu-ray WritersReplies: 11Last Post: 7th Feb 2008, 21:00
