Results 1 to 12 of 12
  1. some MPG file went through fine when I added it, and some get this GOP header error, the full error is like this
    The video Sequence header is incorrect
    A video sequence header is necessary for every GOP in standard DVD
    I can't seems to reencode the file using TMPGenc, any other ideas?
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Womble mpeg vcr has a GOP fixer, i've used it with mixed results.
    He's a liar and a murderer, and I say that with all due respect.
  3. Try de-mux and re-mux with TmpgEncPlus.
    It will re-write the header for the file.
    canada
    Tmpgenc/file/mpeg tools/merge and cut.
  5. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    You can also get the trial version of VideoReDo and use its "Quickstream Fix" to repair the file.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  6. Originally Posted by Faithful Follower
    this didn't work, it didn't let me remux when I did it.
  7. Thats rather strange...Any error messages?
    EDIT:
    What format was the audio file after you de-mux?
    Mar 2003
    Uranus
    There is a program that does nothing but insert GOP headers.
    I forgot it's name. look in tools
  9. Originally Posted by Faithful Follower
    EDIT:
    one was the .m1v and one is .mp2.
    i'll try the other software u guys listed.
  10. here's the error
    22564 s packets cause buffer underflow the MPEG file might cause error when it played
  11. Originally Posted by warlock110
    forget about demux/remux......
    like someone else said, use TMPGEnc>MPEG Tools>Merge & Cut> then select MPEG-2 Program(VBR).....this has worked every time for me
  12. that works for me too
