Hi
I have reauthored some VOB files from various DVD's, ie saved scenes from various films in VIDEO_TS folders using DVD Shrink. I now need to compile a DVD from these scenes using Record Now DX. I have created 10-12 VIDEO_TS folders containing VOB files. When I burn the folders and play back on the DVD player, only 1 scene is burned at random. the others are not detected.
any ideas please of how to compile this in the sequence that i prefer.
You won't know, until you ask
you must join all video_ts folders to one folder. use for example tmpgenc dvd author, add dvd video.
thanks Baldrick
do you know of any freeware programs that can do this also. Would it be better to convert the VOB files to MPEG or will i lose quality.You won't know, until you ask -
Hello,
All you need to do is load each vob seperately and create a menu in tmpgenc dvd author. Use the add dvd video like Baldrick suggested. Look for each vob you have then you can make menus from them (or the ifo file if you have multiple vobs in each folder).
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Swapping M2TS files from Encore authored Blu-ray
By fxtm in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Apr 2012, 05:46 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Need NTSC files to be authored in PAL??
By yodnnee in forum Authoring (DVD)Replies: 6Last Post: 24th Jan 2010, 03:40 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
