I have a questions on file types.
What is the difference in quality between them? Specifically, xvid, svcd, and vcd.
For example, if I have a 200meg file of each type and want to convert one to mpeg2/dvd compliant, which one should I use? I will assume the svcd but I cant be positive.
Thanks everyone.
LG
Is a Mercedes better than a Buick? How about a brand-new Buick versus a 25-yr-old Mercedes?
Having re-read your question, the answer is use whichever one looks best.
If you are going to re-encode, source file format is irrelevant. If each file is of identical video, and has identical size, it is probable though by no means certain that the XVID would be the best. Though you may have framerate and/or re-sizing problems to deal with.
making a compilation vid from various file types/sizes
By pooksahib in forum EditingReplies: 4Last Post: 13th Jun 2011, 15:39 -
File types and DVD player
By rogmath in forum Newbie / General discussionsReplies: 10Last Post: 7th Jan 2011, 14:24 -
Putting different types of file formats on to DVD-R
By carl606 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2010, 05:11 -
file types when authoring a blue ray disc
By michcio in forum Authoring (Blu-ray)Replies: 2Last Post: 18th Jan 2010, 12:47 -
Blue Ray player file types
By plasmannc in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Dec 2008, 18:32
