What program can I use to convert my tv programming to some format that I can put on dvd?
Sonic MyDVD works great with Media Center to burn shows to DVD (and make nice DVD menu's, backgrounds, etc)
Panasonic E-85 & Panasonic E-55 dvd recorders
Gateway 510XL with Media Center 2004
External Iomega DVD-Superdrive (writes DVD-Ram) -
I have already tried Sonic MyDvd. I have the version that was preinstalled when I bought the computer. The version I have does not have the option to change recording formats. I have the HP m260n media center and I've used the m360n and m370n and both of those had a different version of MyDvd that would convert or let you change the format before recording. I've tried updating my version and no changes take place.
DVR-MS is MPEG with metacode embedded.
Go here and click on DVR ripper:
http://www.thegreenbutton.com/downloads.aspx
Download, rip, and then you should be able to use something like TMPGEnc or any number of editors or authoring apps in our tools section to continue
Can anyone help me with using DVR-Ripper. I unzip the file and then I'm lost. I get a list of several files. After messing around and opening some, I install something called TVShowExport, but before it installs I get an error message saying the program is for evaluation purposes only. When I run the program and select a file to convert, I get a Microsoft error message. Can anyone help me out?
I get the same results. The program is NFG.Originally Posted by 49erfan33
Sony VAIO, 3.2 gig, 512 meg, 180 gig HD, XP MCE
Dual tuner recording = split files in Windows Media Center Vista
By yoda313 in forum Media Center PC / MediaCentersReplies: 9Last Post: 14th Jan 2009, 02:10 -
How do I change the recording folder in ATI Media Center?
By yoda313 in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2008, 11:29 -
Firewire or usb2.0 for external drive media center recording? esata?
By yoda313 in forum Media Center PC / MediaCentersReplies: 29Last Post: 8th Aug 2008, 20:42 -
Recording from S-Video input to Windows Vista Media Center
By Velcro Face in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 01:56 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33
