Results 1 to 9 of 9
  1. Is there any difference between a 30 dollar (from meritline) external 5.25" drive enclosure and a 80 dollar one? Besides the fact that the more expensive supports both USB2 and firewire?
    -Yar, matey!-
  2. I wouldn't have thought there would be much difference in the function - an encosure is basically a glorified connector, isn't it? Where there may be a difference is in build quality. It may feel weak, plasticky and have some less-functional designs like the latches to hold it shut and so on.
    I'd say give the $30 one a shot and see how it goes.
    Cobra
  3. Yes there are some differences.
    Make sure it supports UDMA 48bit for 250gb drives.
    I would also make sure it has a quality chipset like VIA and or Oxford
    Originally Posted by jagabo
    Dec 2002
    Costa Rica
    Cheaper cases will have crappy fans that probably will die too soon or will sound like a blender. Still small fans are cheaper than difference in price of the cases.
  5. Member CoasterCreator's Avatar
    Aug 2004
    somewhere in time & space
    well its true connections ( usb2/ firewire ) and the power of the fan. all make the difference , you want it to keep it as cool as possible. example I have a 250 HD in a usb2/ firewire case and it likes to freeze after extended use. . I have to shut it down sometimes to unfreeze
  6. Well, I'm using this for a 4x dvd burner (4x is the max it can handle through a usb connection i hear, i lucked out ), so I dont think the fan will be a problem. And if it is, it takes max 20 mins to burn something, it wont be overheating..(or so I hope, lol). I guess I'm going with a 30 dollar one, then.
    -Yar, matey!-
  7. 4x was the top for CD burners through USB 1.1 (I think that's where you got your numbers), but I think USB2.0 can beat that with DVDs. It's about as fast as firewire, and I have no problems burning DVDs at 8x in my firewire case.
  8. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Biggest concern is bridge chipsets. Some are better than others. Oxford is good, so is TI.
  9. OK, thanks. I just ordered the 30 dollar one (which only came out to 25 including shipping, I dont know how that worked out...) and I'll update when I get it and have a chance to test it out
    -Yar, matey!-
