Has any one ever got a bad disk? I have got one bad disk so far. The movie is Stephen king's IT. It has a screw up line at the bottom of the screen, they edited out the fade in and fade out from comercial braked which make its no flow well, also deleted a scene where georgie runs down into the basement.
So are there any other bad vcd's?
I really wouldn't call that a bad VCD, just a poor encoding job. They probably removed the scene to make it fit on the disc.
Tom Green Sucks!
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
