I have been trying unsuccessfully to create motion menu's with DVD-LAB. I am using the trial for the "regular" version of DVD-LAB. I have added a M2V file to the menu background, added a JPG pic on top of it with transparency so the motion is visible thru it, and added a title to the screen top. I have tried this 2 ways, both unsuccessful.
1) do the above and then go straight to COMPILE DVD. doing it this way, I lose the JPG image and the TITLE at screen top, and ONLY see the M2V background in motion and any buttons that were added - I lose the JPG and the TITLE.
2) render the motion menu, then add back in as background. doing it this way, I get a (large - 3+gig) AVI file, that has all the images and the motion when played. however when I use TMPGenc to convert it to M2V, the resulting M2V does not have any motion to it. It has the TITLE, the JPG, and a static background. I have viewed the M2V from within DVD-lab and from a different player, both show it as static. is there som eother way to convert the AVI back to M2V, or some required settings for TMPGenc to do it properly?
patrick
Patrick,
I only use DVDLab occassionally, but in Maestro, I do motion menus using your method 2 and it works fine. I render the motion menu to AVI in Sony Vegas Video 5, encode to m2v using TMPGEnc, and place on the menu. It has worked fine. I don't know why you would be getting a static m2v file. What are your encode settings? Do you watch the preview while it is encoding? If so, does the preview show the motion properly?
Sorry I can't be more help -- but I think that your approach should definitely work.
eric -
Shuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
hauppauge 950q, 1600, 1250 -
To achieve this, you will need something more than just DVD-LAB. You'll also need a video editor, like VideoFactory 2.0.
Look here: http://www.mediachance.com/dvdlab/tutorial/motionmenu.html
Scroll down to '2. Motion Menu With Overlay'.My opinions may have changed, but not the fact that I am right.
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
