I want to add my own logo and subtittle into a mpg( mtv )
but i don't know how to make my own logo and subtittle, can someone kind enough to guide me. Thanks a million.
Results 1 to 12 of 12
The best way to do this is virtualdub and its filters plus substation alpha v4 or you can use something like Ulead Media Studio Pro.
Hi Pied-Piper, i know using virtualdub but i don't know what filter with what substation alpha v4, do u mind if u could kindly guide me along. Thanks
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
you could try the logoaway filter.with right settings, you can apply a logo via alpha-channel!
Aloha!
My name is ®@g£. I´m just curious...
were can i get the logoaway filter
or alpha-channel.
//®@g£
_________________
Beware of yellow snow!
•••• ×3m®@g£²°°¹™ ••••
<font size=-1>[ This Message was edited by: X3Mrage on 2001-11-28 06:17:34 ]</font>
<font size=-1>[ This Message was edited by: X3Mrage on 2001-11-28 06:18:10 ]</font>
<font size=-1>[ This Message was edited by: X3Mrage on 2001-11-28 06:18:47 ]</font> -
use google and look for : virtualdub logoway filter.
The usage of alpha-blending is explained on the home page by the author of this filter!
<font size=-1>[ This Message was edited by: Dragonsf on 2001-11-28 06:45:06 ]</font> -
Check out this help guid. Should help you with adding subtitles with substation alpha.
http://www.vcdhelp.com/subsvirtual.htm
Good luck -
The "subtitler" filter is designed to draw text onto video.
and you can download it from http://www.virtualdub.org/downloads/subtitler-2_1.zip
And the Location of Substation Alpha is:
http://www.eswat.demon.co.uk/
Both are Free.
The author of subtitler filter is the same author of virtualdub Avery Lee.
The filter itself has no interface to edit scripts.
You can find the guide at this great vcdhelp site.
Good luck. -
guys i try the above method but i still do it .
may i know if there is any kind soul that would teach me step by step. from the very 1st step in how to make your own logo, thank you -
Pied-Piper i would like to know if you can reply my email , my email is Ducati9i6@yahoo.com.Thanks a lot
Regards
Ducati916
Why do you want to know this ?
You can private message me !
BTW you've linked "Thanks" to your e-mail address !
I missed this topic for a while,sorry.
I think almost everything related to VCD stuff can be found at this great site and its forum.
It has helped me a lot. But the bad thing is that the forum or the site is sometimes down and I hope baldrick solves the problems.
Also the site's navigation is very easy and good.
I will post this in a new topic later.
Running Subtittle Workshop in Win 7
By carlmart in forum SubtitleReplies: 3Last Post: 4th Nov 2011, 05:05 -
How to create logo using aegisub
By Mildragon in forum EditingReplies: 2Last Post: 25th Oct 2011, 03:28 -
Newbie question for adding subtittle to ripped MKV
By yd8552 in forum Blu-ray RippingReplies: 2Last Post: 29th Oct 2009, 16:59 -
how can create sub/idx with my logo ?
By persiansubtitle in forum SubtitleReplies: 0Last Post: 14th May 2008, 11:25 -
Help us create a new VideoHelp.com design and logo
By Baldrick in forum FeedbackReplies: 106Last Post: 30th Sep 2007, 23:36
