Hi All..... I have managed to extract the vidio stream (Xvid) and the audio stream (wav) from an "ogm" file using virtualdub.
And then put the two back together again using Dr.Divx, but this took about 4 hours !. Is there anyway of putting the video & audio streams back together without re-encoding?
Thanx in advance.
Hello,
Umm... Not that I know of. That's what REENCODING means as far as I can tell. You have to remix the two to make a new video type.
Cant you just use VirtualDub or Nandub? Theres no need to re-encode anything is there as you only muxing...so use Direct Stream Copy...should take about 5mins.................
I agree. VirtualDub > Open AVI. On audio menu > WAV Audio > specify WAV file. Set both audio and video to Direct Stream Copy then Save as AVI.Originally Posted by monzieIf in doubt, Google it.
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 15:18 -
What format for encoding to get both Audio and Video tracks?
By DaveFresco in forum Video ConversionReplies: 3Last Post: 2nd Jun 2010, 03:48 -
Add new audio to DVD without re-encoding video??
By vulture99 in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 16:23 -
New CPU:Video/Audio Encoding and DVD Authoring
By Maikeru-sama in forum ComputerReplies: 6Last Post: 29th Apr 2008, 14:56 -
Encoding - Audio fine but video running fast
By adeleander in forum ffmpegX general discussionReplies: 3Last Post: 23rd Dec 2007, 15:11
