Converting avi's to svcd and adding subs.
Am using tmpgenc and ffdshow. How do I change linespacing ?
I can change the distance between letters, so I can squeeze them tight together, but I want to have less distance between the upper and the lower line. I can't find such a setting.
I want the subs to be in the lower black border on 2.35:1 films, instead of "cluttering" the image.
But with the fairly big default linespacing I have to choose a way to small font to keep the upper line from being in the picture.
/jima
Using your method you can't - the subs are added to the video before the image is resized and black borders added (by TMPGEnc).To position the subs lower in the black bottom border, you have to resize and add borders, add the subs, then feed it to the encoder. Usually done with filters in VirtualDub or avisynth, and frame served to encoder (TMPGEnc).
/Mats -
If your source video has black borders, then yes, you can. Most AVIs don't, hence neither ffdshow nor VobSub has any black borders to place the subs in!Originally Posted by jimA
If VobSub works, why do you insist on using ffdshow for the same job?
If you "can do it just fine" why do you ask?
Please just tell me to buzz off if I (by mistake) should try to help you in the future...
/Mats -
Helping ? You are not helping. You are just insisting on telling innocent newbies false information.
First
https://www.videohelp.com/forum/viewtopic.php?p=981046
and now in this thread.
If that's all you wanna do then buzz off. If you wanna help then read on.
The reason I don't (continue) to use vobsub is beacuse of some codec-problem (I think) that makes the video jerky. It doesn't get jerky when using ffdshow.
/jima -
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 14:03 -
What is FFDshow?
By terrypin in forum DVD RippingReplies: 11Last Post: 7th Apr 2010, 17:26 -
RF Modulator with S-video line-in or composite line-in?
By Disco Makberto in forum RestorationReplies: 30Last Post: 24th May 2009, 15:11 -
ffdshow line spacing
By kRa in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 16:43 -
i bought 3 movies on line but they don't download they play from on-line
By N8DOGB4000 in forum Video Streaming DownloadingReplies: 6Last Post: 10th May 2008, 16:20
