i have been told that i can using VobSub
so i have put the movie and the sbtitles in the same folder with the same name, but than the program crushes
without the program it works
why?!?! and how can i add subtitles?
use another programme,winavi isnt really reliable with vobsub,whereas another like tmpgenc will let you run vobsub in the background and it will put the subs in while its converting-but this way they will be on screen all the time,and not selectable,what you have to do is make dvd compliant mpegs,then author it with ifoedit for quickness,or any programe of your choosing.
WinAVI (10) - Subtitles?
By jlrm365 in forum Video ConversionReplies: 0Last Post: 6th May 2010, 15:13 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
How to add subtitles?
By jonhal in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2009, 12:58 -
Adding subtitles - using WinAvi
By Hugo2 in forum SubtitleReplies: 27Last Post: 18th Dec 2007, 07:31
