Hi all - sorry for what may seem a daft question, but I notice that if I write a dvd from an authored folder (VOBs, IFOs etc) I get an option to verify the burn.
However, if I burn a disc image, that option isn't there.
Does NERO automatically check the written image?
Cheers,
Wc
No, Nero does not verify ISOs. However you can afterwards mount an ISO image with tools like Daemon Tools http://www.daemon-tools.cc and check the image with (for instance) CD Check http://www.elpros.si/CDCheck/ (there is a freeware version)!
Another, and better way, is to burn your ISOs with DVD Decrypter, there you find a check box that allows you to do a verify.
Hope this helps.
Thanks -
Ah - that's a good suggestion about DVD Decrypter - I'll give it a go.
Thanks for the reply.
Wc
Two isos to DVD9, without loss?
By cinesimon in forum DVD RippingReplies: 6Last Post: 4th Nov 2011, 09:43 -
Combining DVD ISOs
By TheLaserdisc in forum Authoring (DVD)Replies: 0Last Post: 19th Jul 2011, 22:39 -
To many .ISOs to deal with
By jclarkyyy in forum DVD RippingReplies: 12Last Post: 20th Jan 2010, 23:56 -
Archiving-files vs isos
By Dr.Gee in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2009, 15:19 -
ISOs & Vista
By ahhaa in forum ComputerReplies: 3Last Post: 12th May 2008, 10:20
