I have several laserdisc that I want to convert to DVD. The audio is very good as Pro Logic. But I wanted to make a few changes to each of the audio channels, so I wanted to know if there is way a specific way to record stereo and then convert it into 4 independent audio channels?
Please no "It'll sound better in stereo" remarks. As I want to make changes to specific channels and add special effects.
Results 1 to 11 of 11
You might need some expensive remixing software/hardware to do that. There are some freebie/low cost software, but I think they only convert to 2-channel Dolby Digital.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Hello,
Originally Posted by c_hernandez32
Kevin
--old dolby surround didn't have a center channel so if you run across those it would front left, front right, mono rear--
EDIT - Actually I believe if you dub the sound over the cables to the capture device the pro logic should be passed along. I think when I backup vhs tapes with pro logic the sound is carried over in the stereo mix. I can't remember for sure but you shouldn't need to convert anything. The prologic is embedded in the stereo track. It's the receiver that splits it into seperate tracks.
EDIT 2 - Sorry I didn't see the bit about wanting to add special effects yourself. For that you will have to do encoding. Though, it might lose some impact if you fool around with the original source too much (might seem artificial or the balance may be lost, though I haven't done it myself). Good luck.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Huh ?..Is it just me ?..But why did Forum Troll get a warning ?. I cant see anything in his post that goes against the rules of this site !!
Hello,
ANdydd - I think that's his signature line (like my picture of yoda but his is just text). I could be wrong. But he's had that for awhile. Just Private message him to find out.
Thanks, I found the transcoder to split into individual channels. Wierd thing is that I have heard of Prologic II decoding, but I have seen no DVD or video to have five channels in Dolby Surround. Most DVDs say that 4 channels are encoded in the Dolby Surround audio track. Wouldn't that only be Prologic I: FL, FR, Ctr, Mono Surround?
Anyone know of a Prologic II soundtrack on a movie? -
Hello,
As far as I know prologic 2 is merely a fake system. Pro Logic is the only true Dolby for vhs (and dolby surround original). The dvds would either use the pro logic from the vhs release (enhanced a little, I'm sure) or the 5.1 from the theatrical release. Pro Logic 2 wouldn't be worthwile since true dolby digital 5.1 is MUCH better (though I haven't heard pl2 I just know it "creates" the 5.1 effect).
Prologic 2 is no more "fake" than is Prologic 1. SFAIK, the difference is that 2 has (two) seperate, distinct rear channels that are significantly higher in volume than Prologic 1. Both systems are muxed into a standard stereo signal, and must be decoded. I spent some time checking this out as Prologic 2 is the best surround sound you can use on an SVCD. Unless you are the one guy on the planet with BOTH a multi-channel MPEG amp and multi-channel MPEG DVD player, and actually got it to work.
Dolby 5.1 uses seperate signal for each channel. -
Hello,
Nelson37 - I guess what I was getting at is that modern movies don't enocode into pro logic 2. They use dolby digital 5.1 or dts 5.1. That's all I was trying to convey. Sorry.
KeivnDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Prologic will forever be the realm of VHS and LDs and (S)VCD. Though are there any titles, in any format, that use Prologic II?
Originally Posted by andydd
Forum Trolls attempt to lure other Internet users into sending responses to carefully-designed incorrect statements or similar "bait." Amateur Trolls are simply argumentative/offensive/scornful because they can be.
It's just my siggie.You are in breach of the forum rules and are being banned. Do not post false information.
Selecting passthru audio in MPC HC rather than the prologic
By skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 11:37 -
Dolby ProLogic in PHILIPS
By anirban in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Oct 2008, 16:09 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Dolby Prologic IIx. I understood that it will "create" a surround
By andrema71 in forum AudioReplies: 3Last Post: 6th Jun 2008, 10:22 -
ac3filter - back speakers no longer working for Prologic output
By pglenn in forum AudioReplies: 0Last Post: 6th Nov 2007, 23:09
