Hi erveryone, yesterday my friend gave me a VCD and ask me to cut some clips from it, then burn a new one. I can not extract the dat file to HDD, so I tried couple ways:
1.use cloneCD to make a image, open image file, extract the dat, but the movie can not play in PowerDVD, it shows green screen and beep in audio.
2.use vcd cutter open the dat file directly from the VCD, it failed.
So, I use Nero CD speed to check the DISC, and I found there's a blank area in the middle of the cd(in the red circle), is it some kind of Protection? How can I extract the dat file?
By the way, the VCD plays well in any PC or DVD player.
Thanks for help.![]()
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 11:25 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 23:06
