do I have to capture something first?
I mean where can I find the MOST BASIC STEPS for copying from my own VHS video to DVD? I am lost in the trees.
This is what I have on my computer.
Dell 8300, Intel 4 Pentium, w/HT technology
3 g Hz
512 DDR Sdram at 400 MHz
245 g hard drive (s50GB Serial ATA Hard Drive (7200 rpm)
Microsoft Windows XP Media Center Edition
Intel Pro 100M integrated PCI NIC Card
8X DVD+R/RW CD-RW Combination Drive
16X DVD-Rom Drive
Cyberlink software Decoding for DVD drives, Media Center Edition
Infor, 16X DVD ROM and BX DVDRW Drive
Dell Photo Album std
I also have Nero 6, and Videowave7 Professiona Home
I would suggest that you do some reading in the capture section.
The basic rundown is that you need to capture the VHS output to your hard drive. There are a number of ways to do this and there are a number of devices you can use, ranging from a PCI capture card or an external device that connects via USB or firewire. Once captured, you may or may not have to/choose to re-encode the captured file. Then you need to author the file into IFO, BUP and VOB files. Then you need to burn these files using a suitable template in your favorite burning software.If in doubt, Google it. -
I appreciate your comments so, so much. Thanks. So I will learn how to capture to my hard drive. Then I will look at re encoding to see if I have to do that or not. What I am not sure of is how to author that into VOB, backup, and IFO files. Do I do that with DVD.decrypt? But I suppose my old VHS programs are not encrypted anyway.
Is there another term for authoring?
Sincerely, new new newbie -
Authoring is simply turning your MPEG-1 or MPEG-2 file into IFO, BUP and VOB files. Check out the Authoring section also.Originally Posted by gustf7131If in doubt, Google it.
NEWBIE Burn HD DVD
By Wally 2007 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2011, 21:10 -
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 03:35 -
Newbie Frustrations - VHS to DVD or Comp Help
By BrianJ844 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Aug 2010, 12:01 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Which VHS to DVD method for Newbie
By Anonymous8743 in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 08:49
