Hi guys,
I have two video clips which I'd like to encode, and would appreciate a bit of help, the thing is, they're in slightly odd resolutions, one is in 480x280, and the other is in 608x256 - these aren't resolutions I've come across - they're widescreen, but is the aspect 16:9??
So any help would be appreciated - what program to use etc etc.
Thanks very much,
Rob Lewis
A DVD compliant mpg's aspect ratio is determined by it's attributes. For example you can have 720x480 in either 16:9 or 4:3.
That said if your video is displaying by it's resolution then the smaller one is close to 16:9 and the larger isn't close at all. What you need to do is determine the attributes of your video. Try this tool. https://www.videohelp.com/tools?toolsearch=gspot&s=&orderby=Name&convert=&dvdauthorfeatures=
I've found that Ulead Media Studio Pro has been able to do anything that I can think of or tried. I haven't tried importing video with odd resolutions like you have but providing it will accept the video you'll be able to accomplish what you want easily. The smaller video will be the easiest if the resolution is the display size. All you would have to do is create a DVD compliant mpg in 16:9 format. You could do the same with the larger one but the aspect ratio will be screwed up (if the resolution is the display size). You can fix this by overlaying it with the correct ratio on a black background or cropping the edges. -
Ooo, sounds like fun
But thatnks very much for your reply, I'll give it a go, and if I need any more help, I'll be sure to come back here!
Thanks,
Rob Lewis -
LOL actually it shouldn't be that hard as long as you can find an editor that will acept the video. Ulead Media studio Pro has a free 30 day trial, let me know if it accepts the video if you try it.
Youtube HD Resolutions
By bseos in forum Video Streaming DownloadingReplies: 12Last Post: 14th Oct 2011, 11:50 -
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 03:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 13:13 -
Question about resolutions
By ShinKyo in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 09:44 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
