This is not a problem or question. I'm offering this as a tip.
I have the Pioneer DVR-510H-S and discovered that I can use it to digitize my LPs. Previously I had to connect my computer to the stereo system but this was inconvenient. Now I just set the DVR to its 1-hour record speed, which records audio in PCM, and select record. It doesn't matter that there is no video signal. In fact, the lack of a video signal allows me to record more than 7 hours of music on a DVD-RW even though I'm using the 1-hour record mode.
I record directly to the DVD-RW rather than to the hard drive. I format the DVD-RW in the Video mode and must finalize the DVD in order for my computer to read the files. I have a Mac, so I use Cinematize to rip the audio to AIFF files on my hard drive from which I can then use other software for filtering and track separation.
Technically, I can also play the audio-only DVDs as I would a video DVD. The menu shows the individual albums I've recorded. I suppose if I used one of the other recording settings that encodes Dolby Digital audio I could get more than 30 hours of music on a DVD this way, but I haven't tried that as yet.
Results 1 to 12 of 12
I would not do AC3, as it tends to compound errors. If you want to filter, you're doing perfect already.
I'm thinking of doing the same thing.Originally Posted by Frobozz
What software are you using for filtering and track separation?
I don't have a Mac but sometimes programs are available for multiple OS's.
Thanks. -
All of the applications I have for filtering and splitting audio files are Mac only.
They are
CD SpinDoctor (bundled as part of Roxio's Toast)
Bias' Peak Express
Felt Tip's Sound Studio
Griffin's Final Vinyl -
Use SOUNDFORGE for cleaning up audio.
http://www.digitalfaq.com/restoration/audio/soundforge/soundforge.htmWant my help? Ask here! (not via PM!)
What would happen if you used the 2, 4, or 6 hour mode? Quality not good enough?
Also, is there any software that can detect the silent gaps between songs and make a separate WAV file for each song? Trying to do this by hand on a long contiguous recording is cumbersome. -
On my Pioneer DVR the only way to record PCM audio is to use the Fine (or 1-hour) record mode. Any other setting records audio in 2-channel Dolby Digital. So yes, there is a quality difference with the longer time setting.Originally Posted by nixie
Great tip frobozz! I will check to see if this works with dvdr-7000. I am working on laptop for now which does not have audio line in.
Thanks! -
The Toshiba D-KR2 allows the user to choose low video rates, as well as choose which audio encoding scheme to use (D/M1, D/M2, or L-PCM). Even so, the maximum time one can get for L-PCM audio is 3hrs 21min.
Also, note that for all NTSC DVDs, the L-PCM sampling rate is 48k, while for a CD the sampling rate is always 44.1k. So you can not take the audio bitstream from a DVD and put it on a CD without either getting a pitch change or resampling. -
Sorry if I'm being daft here but why would the sample rate have any effect on the pitch?
You're not daft at all! The problem is that if you record the PCM directly to CD without resampling, the result will be that the pitch sounds lower, because each cycle of the waveform was broken into more pieces than it would have been if it had been sampled at the standard rate for a CD (44.1 KHz). It's just like playing a 45 rpm record at 33 1/3 rpm (well, the ratio is different, but the concept is the same).bigeck said:
One way of dealing with the problem is to resample -- many software packages do this automatically and you really aren't aware that it's happening. The downside is that it takes time, and also the automated systems choose a "good" algorithm, which may or may not be well-suited for your specific recording.
Resampling also tends to accentuate any errors and often accentuates noise, so for these reasons it is often preferable to sample at the proper rate and avoid resampling.
Getting ready to digitize some VHS tapes. *New questions*
By Crow550 in forum Capturing and VCRReplies: 66Last Post: 24th Aug 2012, 22:12 -
What's the highest quality AVI to digitize video to for future editing?
By jbandy1 in forum EditingReplies: 21Last Post: 22nd Aug 2011, 11:11 -
It started out so harmlessly! I just wanted to digitize my old home movies!
By ctakim in forum MacReplies: 6Last Post: 20th Jun 2011, 18:35 -
Song-Artist List for Music Imported from LPs
By Trainmaster in forum AudioReplies: 1Last Post: 11th Jul 2009, 22:14 -
Using camera/WinDV to digitize old VHS... coming out too dark...?
By garybeck in forum Capturing and VCRReplies: 6Last Post: 8th Aug 2007, 06:53
