Question # 1
I have a TDK 8x DVD burner and 8x Memorex DVD-Rs.
Whatever program I use, I never get 8x speed.
With nero it only gives me options up to 4x. When I use DVD Decrypter it lets me pick speeds well over 8x but when I do pick 8x the actual burn speed is 1.2x. Anyone else have this problem and fix it ?
Question # 2
In the past when I made a back up of a DVD with DVD Shrink it would automatically rip it then burn it to the DVD-R. For some reason now when it finishes the rip it stops then I have to manually open Nero and burn it.
I cant find any setting that might fix this. Does anyone know what I need to do.
Thanks for any help !
BM
I suspect you need an updated firmware.
The firmware determines the write speed of the different media types, among other things. As new media comes out there are frequently revisions to the firmware
You may have turned off the burn to disc feature in your preferences. I would check that for the burning problem.
Not the exact problem but I just remembered this - remember to turn off the "Enable Burning with Nero" option in the DVDShrink preferences. That'll cause problems if it's on.
Not sure with TDK but I know that with my PX708A, in order to burn at 8X, I need to use DVD+R. DVD-R will only burn at 4 speed with my burner.
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 04:06 -
store video & also burn chapters according to datestamp (vista & dv
By Nicola-Pickle in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 08:08 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 08:35 -
How do i change the default writing speed in Nero when using DVDshrink?
By wallacem4141 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 06:15
