this is realy niggling me now , just lack of knowledge is suppose
ok avi
701 MB (701 MB), duration: 2:01:58, type: AVI, 1 audio stream(s), quality: 33 %
590 MB, 677 Kbps, 23.976 fps, 448*240 (16:9), XVID = XVID Mpeg-4, Supported
110 MB, 126 Kbps, 48000 Hz, 2 channels, 0x55 = Lame MP3, Supported
now when i load into tmpgenc select ntsc , cbr mpeg 1 layer 2( not 16:9) , do the usual select the file leave at 1:1 select other settings set to advanced 1:1 vid arrange full scr keep aspect , it makes a file size 152.45% the size of the dvd , which wont fit , if i clip the end of the avi by a few seconds in source range and carry on through it fits ok but when converted there is no sound ?
i have the lame mp3 codec installed as well as gknot and kazaa packs , whats happening and why and how do i resolve the issue
i have tried de-muxing the audio to uncomp wav and then selecting the wav as the audio source in tmpgenc but its way out of sync ?
ggrrrrrr , help please guys
Results 1 to 9 of 9
What are you trying to make?
MR smurf sir , i am honored
mpeg m8 for burn 4.7 g, and i agree on bitrate , thought it was that , so i`d have to use unlock but i kinda get lost in unlock , coz then i cant use the wizard and dont know how big the output file will be -
i really would like pal but its ntsc to start with so insted of getting jumpy playback i`l stick with ntsc , we all got multi standard here anyway
oh and i have kinda been uninstalling a few codecs and re-installing and not tmpgec gives me ( warning nothing to ol bframe decoder lag ) umm , what did i do this time to get that message ?
So.... you're trying to make a DVD-Video from XVID files?
You can use GSPOT to analyze the files, see what you got. It will let you know what codecs you need when you render.
Then encode to MPEG ... then author DVD-Video.
Size of the files is determined solely by bitrate.
Quality of video is determined mainly by the allocation of bitrate per pixel (resolution).Want my help? Ask here! (not via PM!)
oh and foget the warning message , realised now what it was , well i`m always rushing and never concentrating
use a bitrate calculator to make your file fit to dvd
member since 1843
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
AVI mono movie too big to burn on to single layer DVD-other options?
By nzdreamer55 in forum Authoring (DVD)Replies: 7Last Post: 29th Apr 2011, 14:45 -
avi vid too big?
By miilk in forum Newbie / General discussionsReplies: 5Last Post: 7th Oct 2009, 20:42 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
Adding subtitles to a BIG Avi file and then burn to dvd(?)
By Hal05154 in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 15:15
