I have a dmr-55 unit and it records fine and finalizes a disc fine, but after it finalizes, the unit just freezes. You have to unplug it to get it to come back. Is there a firmware update to fix this. I checked panasonic's web site, but did not find anything.
Bad media? That would be my first suspicion. I have a 50 (same but a little older) and it's picky about the media you give it.
I had my E20 do that 2 or 3 times, seemed like it was when it was getting too hot. Make sure all intake vents and behind the fan are clear, also don't have it on top of anything or have anything on top of it.
Panasonic DMR-ES35 fails to read discs
By lilblu in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Sep 2012, 14:14 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 16:27 -
DVD-RAM discs causing Panasonic DMR-ES10 recorder to 'fall-over'.
By dreamcloud9 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 7th Mar 2008, 00:24 -
DVD-R discs work and then fail in Panasonic DMR E85H
By herefordjw in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 12:09 -
Panasonic DMR-EX85: Recording NTSC discs on UK model
By webstar in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Jul 2007, 18:57
