ok so i demuxed a vob file into an m2v and ac3 files, the ac3 file lasts 1 hour and 35 minutes like it should but for some reason whatever i play the m2v file in it says it only last 1 hour and 10 minutes, then when it comes to the end of the 1 hour and 10 minutes and the progress bar reaches the end it carries on playing till 1 hour and 35 minutes. this is causing me serious problems re-authoring!
anyone know know an dhow i can remedy this?
thanks for reading!
mik x
Hello,
What are you doing with it? If you want to just make a new dvd you can use tmpgenc dvd author or another program that accepts vob files directly (no demuxing needed).
Kevin
---You could always delete the .m2v and .ac3 files and resplit them _ of course, assuming you didn't delete the original vob---Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
the problem i have originally is that this is a dvd that was recorded using my phillips stand alone dvd recorder. when i used dvd decrypter to rip it, i did try and use tmpgenc dvd author but it said it didn't recognise the files and that it wasn't an mpeg 2 (i have no idea why) - so i decided to demux and try again. i'm basically just wanting acertain section of what i recorded.Originally Posted by yoda313
Hello,
You could use dvd shrink and go into the reauthor mode. In there, (can't remember where right now) you can select which chapters to rip and/or how much of the whole movie. Then you'll have just the vobs you'll need. That might help.
I had this same problem, it was caused by the layer break information in the M2V. Solution: when demuxing with VOBedit, check the option "split on new VOB ID" - this will give you 2 M2V files split at that point which you can then use to author.
OR, using DVDdecrypter, in IFO mode (and stream processing enabled with all the video files checked to 'demux'): go into the settings for IFO and under file splitting choose "layer break". This is the best method IMO. -
cheers guys - the reauthor worked just fine - next time i do this i'll try the dvd decrypter method.
cheers for all the advice - i'd have been stuck without it!
mik x -
DVDShrinking a DVD without compression is a fast and reliable way of fixing bad authoring or bad ripping.
Once you have the .m2v files and identify this problem, another option (more straightforward) is to use Resetream and select to fix broken GOPs and reset time stamps.
BTW, these standalone DVD Recorders seem to create a hell of a lot of problems when further processing the video.The more I learn, the more I come to realize how little it is I know.
crop m2v video file
By robbtek in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 11:58 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 05:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
