I used avisynth and then virtual dub to create an AVI.
However when I go to convert it to WMV using Windows Media Converter I get the following error: "The input media format is invalid (0xCOODOBB8)"
I normally have no problems when I want to convert AVI to WMV. However this is the first time I have used an AVI I have created in VirtualDub. Has someone else experienced this problem and can offer a solution?
Thanks in advance!
If you are using WinXP possibly try Windows Movie Maker ?
If in doubt, Google it. -
Hi,
sorry for the belated reply but my ToDo list grew and this got pushed to the bottom of the pile.
No I havent recently installed service pack 2 and Im not using winxp.
Any other ideas? Thanks for the help so far! -
actually it sounds like this problem here ...
http://www.kbalertz.com/kb_299290.aspx
however Im not converting from mpg, im converting from avi.
This might make it clearer! -
Was it a file you captured using virtualdub ?
Normally if I have any issues with AVIs, I just run them through virtualdub on Direct Stream Copy for both audio and video and so that it basically just rewrites the headers.If in doubt, Google it.
wmv video file error
By MaddogX in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2011, 22:10 -
error message coverting vob to wmv
By DaveE in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 07:50 -
convert to wmv with automkv problem,error.
By eao1 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2008, 20:30 -
WMV to MPEG gives error
By tommm in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 15:46 -
WMV to FLV conversion Error for some videos
By meena in forum LinuxReplies: 2Last Post: 4th Oct 2007, 21:30
