hi.
im converting a file from avi to mpeg2 using tmpgenc express 3
ive converted the file before but deleted the mpeg2 file so am having to re do it again.
however i keep getting this error message now.
anyone know what its about ?
There is no quoted number of character strings "%.2f"
This error comes out if your output drive doesn't have enough free space. I guess your "C:\" drive doesn't have enough space for cache or the file is larger than 4 gigs and the drive is fat32 (fat32 handles only maximum 4gb files, use ntfs disk structure instead).
I'll recommend to empty the trash, remove unneccessary files and defrag the drive to start with. I highly fragmented drive could also cause this problem.
Check if the output file is larger than 4 gigs, if it is try to split the file, decrease output size or convert the drive to ntfs (NTFS should be standard if your running xp or win2000). Hope it helps!My opinions may have changed, but not the fact that I am right.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 20:13
