I have been asked to make a widescreen DVD I am having no with getting the vision to play correctly on both widesceen tv or 4:3 tvs. The problem I am having is getting the menu to do the same if make a 16:9 menu it plays correct on WS but letterboxes on a 4:3. Does anyone know how to make it play correctly on both tv formats?
Thx
Crusty
I usually make widescreen DVDs with Pan/Scan menus. Looks better then letterboxed menus.
For both (letterboxed or Pan/Scan menus) you'll need 2 subpics for each displaymode. I'm authoring with Scenarist, here you only add the second subpic, set the properties as needed for both substreams and add the btt-highlight as needed.
I really can't help you in "how to solve this with Meastro", but woulb be interested too. May you should post this problem at doom9's forum cause there are some maybe helpful guys.
Cona -
Have you tried setting the "Force to Pan/Scan" options in the Project Properties?
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
