I have the Dazzle DVC 150. It is an external box that connects to the computer via USB2. On a few tapes the record volume is a bit low. According to support I cannot change the record volume but instead I should change the volume durring editing.
Does any one know of a way to increase the record volume? (The normal record settings have no effect because it is an external hardware device). Maybe a registry change?
I'm not familiar with this hardware but what I can say is this: If the signal to noise ratio is good, simply use besweet to amplify the audio stream after it is captured.
That's one answer but I'd much rather increase it durring capture and avoid extra steps.
Dazzle DVC 100 - Message to change to Standard Definition
By fhmesq in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2012, 17:09 -
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum Capturing and VCRReplies: 17Last Post: 23rd Dec 2010, 23:46 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34
