MPEG1 or MPEG 2 to DVD confusion
Question is...do I need to convert from AVI to MPEG 1 or some other format to have my DVD's play in my Toshiba SD2800 stand alone.
From previous VCD burning, I found my stand alone does not play MPEG2. I tried to burn SVCD's in MPEG2 but it won't work in the player. Now that I have a DVD burner, and want to burn DVD's, do I need to stay with the MPEG1 format? Or will putting them in a DVD change things? I am converting VHS (AVI format from SceneAlyzer) to DVDR's. Do I need to convert them to MPEG-1 format since my stand alone didn't play the SVCD's in MPEG 2. Or am I really on the wrong track. I have done lots of reading on this site and nothing really addressed this. Or I misssed it completely. Please help me understand if I need to convert the AVI's I capture to MPEG 1 or 2. Or if it is DVD, does that make the point moot? Thanks.
Canopus ADVC-100
SceneAlyzer for capture
When this question is answered I will decide between TMPGEnc, CCEncoder, or Ulead VideoStudio 8
VS8 edits, I understand.
Undecided on Authoring but again, maybe VS8
Have Nero 5.5.... for burning
NED 2500A DVD burner
The Toshiba 2800 is my main player, works well. It adheres to true DVD (NTSC) and VCD specs. It will take both MPEG1 and MPEG2 discs, though I suggest MPEG2 for DVD unless it's already MPEG1 format.
Thanks lordsmurf.
I will just go for it then and if the burn doesn't work in my player, I won't qutomatically assume it is the MPEG2 format. That is what I needed to know. Didn't want to make a coaster 1st time out.
I have a trial version of VS8 downloaded. Looks like I will be giving that a try soon. (After Hurricane Frances passes and I am back home)
VHS to DVD help required (some confusion)...
By takearushfan in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2011, 20:28 -
Mpeg-2 editing confusion...
By amtt in forum EditingReplies: 41Last Post: 3rd Mar 2011, 18:47 -
DVD Burning Confusion
By GenManza1 in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2010, 20:18 -
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 16:47 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
