Hi,
I try to convert an avi file to mpg1 (vcd) file using TMPGEnc
but when i drag and drop my file on the page 2 of the project wizard
I only have something put in audio. If i try to open the video manually it says
can not open or unsupported ?
Do you know what caI do to be able to convert it ?
Thanx
info on the file:
File : 679 MB (679 MB), duration: 1:21:58, type: AVI, 1 audio stream(s), quality: 64 %
Video : 604 MB, 1031 Kbps, 29.970 fps, 720*480 (4:3), DX50 = DivXNetworks Divx v5, Supported
Audio : 75 MB, 127 Kbps, 44100 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
Ok I find the answer on this site at
https://www.videohelp.com/tmpgenc#problems
For those who want the solution:
If you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that does not help be sure that you have installed DivX or XviD or MPG2 or DV Codecs, read here how to identify what codecs you need.
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 14:46 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
