I have a question about DVDlab
I used reboot's dvd lab guide but
I'm having some trouble with the motions.
I have a perfect mpg file of my motions, but only if I import them in the program it gives a few remarks. And when I simulate, it turns completely black and only the selection of the first button is visible
How can I fix this?
Or isn't there like a way to import gif files? That would make it a lot easier.
All the rest works fine.
What does it tell you when you import it ?
Did you put the motion background onto the menu, or into the video track UNDER the menu ? (it should be the later)
Have you made sure all your buttons are above the background (bring forward), and that you have set decent values for your highlights ?
Are you aware that the Simulation mode only tests button movement within a single menu page, and does not show a true simulation of the menu (unlike, say, DVD architect) ?Read my blog here.
Ok here's what happened last time:
I tried to import the mpg file, it asks for demuxing first, if i say yes. it has to transcode the audio file first (no importance of course).
And when i drag the mpv file into my menu my bg turns all green with some weird pixels strangely coloured. So it's lost it's image.
If i say no demuxing, and I drag the mpg in my menu it gives this error:
Exception code: C0000005 ACCESS_VIOLATION
Fault address: 004C0124 01:000BF124 C:\Program Files\DVDlab\DVDlab.exe
Call stack:
Address Frame
004C0124 FFFFFFFF 0001:000BF124 C:\Program Files\DVDlab\DVDlab.exe -
Originally Posted by WtFudgE
Needs to be an m2v, right?Your miserable life is not worth the reversal of a Custer decision.
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 16:13 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 17:19 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 21:32 -
DVD Lab 2 error
By XL3/\/7 in forum Authoring (DVD)Replies: 4Last Post: 3rd Jun 2007, 06:54 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 07:52
