  1. Hi, I have the latest version of Nero. Every time that I create VCD, the movie at the end becomes broken (video and audio signal). I already write it on 2X (even though the disk is 4X). it happened to multiple video files. Any suggestions on improving that.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Use VCD EASY. here's the last free version 1.15 you can use:
    http://www.freewareguide.de/neu/neu44.shtml
    Note to Moderators: This isn't considered warez because the older versions of vcdeasy were freeware.
  3. VCD Easy is a great program. For some reason it does not support my new DVD writer
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    What brand of dvd burner do you have? You may have to install FORCE ASPI drivers to get it to recognize your dvd burner.
    http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm
    try that out and see if it recognizes your dvd burner. if not then go to the adaptec website and download ASPI drivers according to what operating system you have. XP, WINDOWS 2000 and so forth. Good luck!
